Replacing lift gate window on hardtop!
Greenwithenvy
One issue my 7 had when I picked it up, was that it is missing the back window. The frame for the lift gate window is all there. Looking on-line did not work, as all I could find was the whole top for sell. So, I had my local glass shop order me a sheet of poly carbonate or Lexan. I order it in 1/8". Thought it would be less brittle to work with than acrylic or plexiglas. Less chance of shattering on road too. Ordered the window seal gasket also. My thought is to make a cardboard template and cut the window out with a fine blade with my jig saw. Smooth off the edges and use silicone to seal within the gasket. I'm sure this has been done before by some of you great craftsmen on this site. Any pointers or suggestions would be helpful. All in all I will only have about $100. into my new window. Thoughts?
