To get a lot of flex you could try Orbit Eye Bushings from Alcam Springs. QUOTE]
Those look good, they look like a Johnny joint and I had not heard of them . I wonder how they handle on road, it appears the outside may stabilize them but they flex under pressure? If I break something up front might have to give those a shot. I definitely wouldn't run revolvers up front, just seems unsafe.
I heard about the leaf spring issue as well but I will most likely run a rubber bushing on the rear spring.
I founds a cheap set on craigslist early last year and run it like that. I haven't had any issues and seem to get lots of flex. That's why I was wondering what happened to the popularity of these things. You can always tighten or loosen the bolt so they open easier or not at all.
I've known a couple that tryed them, they all took them off after a couple trail rides. They take all the pressure off the tire when they open up so you lose any traction you have. They are great for ramp work but not off road.
That has some merit. See video below. I never really caught that before and have watched it a few times. It also keeps him very level though.
As for the ramp, I have heard that before, but figured it was someone that didn't run springs and was hating on the leaf guys for all the flex
I had the "5th link" set-up from sky-jacker. As far as off road goes they always worked fine for me.
When you attempt to accelerate (with a healthy v-8 and 38" tires and without the proper traction bar) the shackles would open up and bind the driveshaft, effectively causing the
Dana 300 to spit it's tailshaft out without the use of proper tools
More good info to be aware of, I do run a ladder as I run softer springs for flex and didn't want to experience wrap... again
. I might be a little short on power though too
Thanks guys for the input. I like to know as much as I can about my
. Anyway, I rounded this up from a run a couple years ago with a Toy. I have to say it is
watching the rear shackle open up. I am the dork in the Cards shirt -as usual-. My buddy's TJ broke once on this (in my profile pics) but CJ007 walks right up and has yet to break anything on it. Score one for the old school
