right size clutch disc for 360 v8
cymbash
camden ar
1980 cj-7 amc 360 4 speed 33.12.50.15 swampers
swapped out a lame AMC 304 for a mildly built 360 and after installation slight vibration as if clutch disc is the wrong size need help:chug::eek::confused:
swapped out a lame 304 for a mildly built 360 and after installation slight vibration as if clutch disc is the wrong size need help:chug::eek::confused:
Most AMC V8 flywheels I've seen have holes drilled for a 10.5" or an 11" Pressure plate.
If the clutch is set right, it would not vibrate with either one.
IMHO, out of alignment or somethings loose is the more likely issue.;)
$45.00
  22.5%
