Rock Hard Rancho
I have a 1981 CJ7 (AMC 258 i6 / 4.2l engine).
The jeep has been fitted with a Rancho “add a leaf” lift kit and Rancho RS5000 Shocks. I think that it may also fitted with reversed shackles, I am not 100% sure of this. The body height is 23” from the ground.
It is also running twin Rancho steering stabilisers and I think that the pitman arm has been dropped (again not sure).
The Jeep is running on Mickey Thompson 31 X 15.50 / 15 Baja Belted tyres.
My problem is that there is absolutely no movement in the suspension, it is rock hard. (I weigh 190lbs and when I bounce on the rear bumper the Jeep moves about ½ inch). The Jeep is dangerous to drive at 40mph. We have very poor tarmac surfaces here and the Jeep feels as if it is going to jump off the road at any time.
I need to improve the ride quality and I think that dampening out the poor road surface is the priority.
Can you please give me some advice as to whether I should change the shocks or springs or both, and if so what I should change to (I want to keep the ride height) and also what could be done to sure up the steering.
Any help is much appreciated.
