Rough running engine
cjTango
- Southern California
- 1975 CJ5
Eng: I6 one-barrel 258 cu in (4.2 L)
Trans: T18
T-case: D20
Axles: D30 (F), D44 (R)
Got one for the carburetor specialists out there…
Here’s the situation:
Starts up easy.
Idle is good, both cold and warm.
There’s a band of “goodness” from idle (900 RPM) to about 2500 RPM with no engine load (i.e. I’m pulling on the throttle cable on the carb manually).
At 2500 RPM, the engine starts to sputter and drops RPM suddelny, like it’s going to stall, but doesn’t. It runs crappy with no power until you give it enough gas to land it at - I’m guessing - about 4000 RPM.
It seems to be okay at the high RPMs, but I didn’t dwell long there.
When I drive it, the same thing happens, except as soon as I load the engine. I have to give it a little gas before let out on the clutch to keep from stalling.
Here’s a link of the engine running and the sounds it makes: https://photos.app.goo.gl/tgWKxO89QJFQ2ut53
It seems like some sort of fuel-air mixture, but I don’t know carburetors…at all really. I just rebuilt this on because of the same issue, but it didn’t fix it. Note: the video is after the rebuild.
Any ideas?
Starts up easy.
Any ideas?
