Rubicon Express 4.5" lift monotube shock (Bilstein) mounting direction
jwnaron
- Denver, CO
- 1979 CJ7 orange, white hardtop, Levi's blue interior, 258 converted to fuel injection,THM400 with "SHIFT" shift kit, Quadratrac TC converted to part-time, warn premium manual hubs, D30 front welded/AMC20 welded rear axle solid piece rear axle, G2 30 spline axle hafts, ARB lockers Front/Rear, High Output ARB on-board air, TR HD Beadlocks, 35" Maxxis Creep Crawlers, Poison Spyder front bumper; Rock Hard 4x4 Rear bumper w/ tire carrier, can mounts and rock cage.
Well I hope the answer to this isn't on here right in front of my face, but after about 15 mins of searching and not finding anything that addresses this issue directly I figured I'd start a post.
I know there are lots of guys on here running the Rubicon Express 4.5" lift kit with monotube shocks. The shocks that came with my kit are Bilstein and from what I can find on the Bilstein site probably the Bilstein B8 5125 shock.
My question is, which direction do you mount these things???
I read that monotube shocks can be mounted either shock body up or down and that a lot of users remove the rubber boot. I can't really see a reason why you want to remove the protective rubber boot and leave the rod exposed. I've heard because it keep mud and dirt from collecting INSIDE the boot, but I personally don't see how that can happen unless the boot is torn. I currently have mine mounted with the shock body down to keep the boot from getting ripped and being on the front lines for damage. I figured the body of the shock could take more abuse than the small rod and rubber boot.
But, I wanted to get some suggestions from people that have more experience than I on the subject. I read that Bilstein says always mount the shock so that the writing is right side up, this would put the rubber boot down I think.
Do you mount the shock boot up or down? These are monotube if that makes a difference. Boot on or off? Difference between the front or rear?
Thanks in advance for your answers!
