Rubicon Express lift kit
Sasquach brought up a couple of good points. I run a cv rear drive shaft and I also changed the upper bushings to the YJ size,too. I did the M.O.R.E shackle reversal at the same time. I also tried to shim the front axle for pinion angle and caster and took them back out. I run six degree shims on the rear axle for pinion angle.
Purple77CJ7 (or anyone else!), I am looking at getting the RE 4.5" kit to replace my 4" Skyjacker lift. I am already running the shackle reversal system (SRS) kit from Rough Country
RCS5060
I know RE springs are 2.5", and my current ones are 2" wide. There appears to be .25" possibly on either side, but I don't have my Jeep with me right now to determine if I can use it as is, or spread them, or will have to convert to 2.5" SRS.
Will the RE springs fit this SRS system at the fixed end, up front? I really don't want to have to swap out the SRS if possible!
