Runaway throttle?
gr8dain
Full Time Jeeper
Got an issue with my CJ. It is a AMC 258 i6 / 4.2l with a 4 bbl Holley.
Last week on my commute home, I was crawling in traffic and my engine decided to rev up to 2,000 rpm. It would only go down if I put it in gear, but it wanted to go 25 or so without me touching the gas pedal. After a few miles of messing with that, it went down to 1,500 rpm.* Then a few miles later it went back to normal.
Last night it did it again and went to 2,000. I got home and looked at the throttle linkage while it was idling at 2,000. Did not see anything odd.* Turned it off. Started it and it idles at normal. About 800.
This morning all was good until about 20 minutes into my commute. This time it got to 3000 rpm and was climbing. So I pulled over and cut it off. Then started it right back up and never had the problem again.
It will happen again. I am just wondering if anyone has thoughts.
Fuel pump?
I don't think it is a floor mat but will check. That does not make sense as I was out of it last night when I turned the key to off. Then turned it back on while still out of the Jeep and it was good. And my floor mat is bolted to the floor so it won't move.
Fuel pump?
