Russell Speed Bleeders
TroyaCantrell
Old Time Jeeper
Orangevale, CA
1966 CJ 6, Buick V6 Dauntless,
Dana 44 rear, Dana 27 front
Trans GM SM 420
First Gear ....... 7.05
Second Gear ... 3.57
Third Gear ...... 1.70
Fourth Gear ... Direct
Dana T-case (twin stick)
1970 Glass dune buggy. Short pan 1600
2008 Chevy HHR SS
Has anyone used Russell Speed Bleeders? I need to replace the bleeders on my front drums and was looking at these?
I also cant find anywhere that it specifically states the size used on the 66. I think it is 1/4 x 28 but found where ones that size say they dont fit my year. I know that a lot of the online systems for finding parts are wrong so i am looking for confirmation on the size and if anyone has experience with these.
The fronts are a PITA to get to and i thought these would help the bleeding process.
I had a pair of them come with my Warn Full Floater axle kit years ago and recently was going to use them on my front calipers. The wrench hex flats were 5/16" instead of 3/8" that are on other brands, I thought they would slip and round off a lot easier since it is a soft metal. The bleeder nozzle was a lot shorter also making it harder to mount the bleeder hose on. Overall I just didn't like the design and never mounted them, I just threw them into the trash. Mine had a 3/8-24 thread on them I believe.
Haven't ever used them on a Jeep but they worked good on my Chevy C10.
Thanks, I ended up getting them because it was the only ones they had at the place I went.
They were a bit longer then the ones i had, at least the hex part was. I also used a one man bleeder setup in addition to the speed bleeders and bleed the system.
Still not on the road yet though.
Troy Cantrell
Build thread - '66 CJ6 :
http://www.jeep-cj.com/forums/showthread.php?t=15075
