Rust guy info
Rust guy info
wood1022
Washington IL
1978 CJ7 quadratrack, 304
Restoring78 CJ7 . Seen a commercial several times do Rust Rust Guy said just scrape or brush heavy stuff off and apply. Said chemical reaction between it a rust makes a seal that won't rust again. I'm g n.a. pull body, so y not use on frame a body tub. Any experience or better idea. Thanks
Re: Rust guy ifo
Restoring78 CJ 7. Seen a commercial several times do Rust Rust Guy said just scrape or brush heavy stuff off and apply. Said chemical reaction between it a rust makes a seal that won't rust again. I'm g n.a. pull body, so y not use on frame a body tub. Any experience or better idea. Thanks
Never heard of the rust guy, but it sounds like a rust converter. To me, best way to remove rust would be media blast - mechanically remove all rust following with a good primer. Short of that, I'd say a rust converter would be a good second choice. I'd remove as much as possible, then hit it with the converter. POR15 makes good stuff as well. They would also be a good second choice. There are folks here who have had great results with converters, and a bunch that swear by POR15 products. if it were me, and I couldn't remove the rust, I'd convert it and hit it with POR15.
Re: Rust guy ifo
X2 on what Shum8 said I have used POR 15 with great results it lasts for years
Re: Rust guy ifo
I'm doing the same thing to my '77 CJ5 . I have been using WD-40's rust remover soak for small parts. Soak it for 24hrs and the rust is gone. It also helps the old paint come off easier. Afterwards clean it well, degrease it and prime. They have a $10 off per gallon deal at Lowes right now.
https://www.amazon.com/WD-40-300045...id=1488839986&sr=8-1&keywords=wd+40+rust+soak
Another product that seems to work pretty well is Auto Tech Rust Prep. It's expensive on Amazon but I picked some up at my local automotive paint store for about 1/2 the price.
https://www.amazon.com/Auto-Tech-Ma...488840227&sr=8-1&keywords=auto+tech+rust+prep
Like others have said. It's best to media blast and coat with epoxy primer.
Re: Rust guy ifo
Another good dip method to try is evaporust
Sent from my SAMSUNG-SM-G891A using Tapatalk
Prep and Etch works well on rust as well. Get it at the bog box stores and such.
It is basically phosphoric acid.Get the bog chunks off and soak.
Before you think rubber gloves and masks, it's pretty harmless to skin.
And phosphoric acid is an ingredient in Coke.:)
I like Evaporust as well. Harbor Freight use to carry it.
