Rusted joints and connectors, all old CJ's
DHugg
MS Gulf Coast
'80 CJ7 304AMC crate with 8KMiles: MC2100 - AMC20 rear w/Superiors - Dana30 front - TF999 - Dana300TC - 35x12.5's - Tilt steer column - Flaming Rvr EZ-Steer Shaft - AGR Super Pump - AGR Super Box II - RockyRidge HD Brace - New home-designed digital TEMP - GAS - OILPR - CALIBRATE gauges.
you talking about the joint where the steering column comes through the firewall and attaches to the steering shaft? if so that one is normally a PITA to remove (in my experiences any way) this may have been done but it wont come all the way out without either removing the steering column a few inches or removing it off the gear box as there isnt enough play in the shaft to get it to slip off the splines
Also, unless you remove the bolt that goes through the joint completely - you will not be able to separate the shaft and the joint. There is a groove in the shaft for the bolt to lock into.
CJ, Brian, thanks for the replies. I have the bolt out at top and the clamping collar expanded and free. Since I am replacing the steering box, I am disconnecting the lower end and the steering box bracket, then taking the box off the bracket.
Patience, heat, ATF-Acetone, hammer, and repeat. I'll get it.
DHugg
LMAO! A perfect example how a 35 year old piece of equipment can make us cringe! :)
quoted for truth :chug:
i have to rebuild my steering gear box because its leaking im just looking so forward to that day.... yea :censored: right :(
$100.00
  50.0%
