Security lug nut holding up spring leaf removal
DHugg
- Media
- 46
- Resources
- 1
- MS Gulf Coast
- '80 CJ7 304AMC crate with 8KMiles: MC2100 - AMC20 rear w/Superiors - Dana30 front - TF999 - Dana300TC - 35x12.5's - Tilt steer column - Flaming Rvr EZ-Steer Shaft - AGR Super Pump - AGR Super Box II - RockyRidge HD Brace - New home-designed digital TEMP - GAS - OILPR - CALIBRATE gauges.
I've had the wheels off several times since purchase in 2009 - single-piece rear axles, front disc-rear drum brake overhaul, and one really good tire and wheel cleaning. After rebuilding the Dana 300 I moved to the other bay of the garage, repacking all tools and parts in a much neater way than before.
Now I'm removing leaves from the ProComp hi-lift springs so as not to shake my boat and trailer apart since completing both last month.
Do you think with the good organization and labelling of all parts and tools I could find the socket adapter that gets this anti-theft lug nut off ???
HELP !!! Can I buy one to match somewhere? Can I get the lug nut off with an alternate methods some more experienced Jeep owner knows about? Can I find someone on the MS Gulf Coast from whom to borrow an anti-theft lug nut adapter?
I think I'll revert to plain lug nuts after I get over this. Not being able to change a tire will leave me in the swamp some night, and the mosquitoes will suck so much blood that the alligators will ignore my dead, bled-white body.
