Shackle not strait up and down
asfaultdemon
- Medford Oregon
- 1981 CJ-5 304 AMC v8 t176 trans dana 300 Tcase d-44 in front,AMC 20 in the rear, 33'' tires alot more soon to come i hope
Has anyone ever noticed that alot of cj's have the crooked shackle syndrom? My passengerside shackle is way crooked. It has all new bushings (energy susp. poly bushings) but still crooked. I also welded all the shackle to frame mounts to the frame . Yes i took al the springs off and make sure they were strait and true to the frame then welded them . Only one i couldnt was the driver front as the steering mount is a bully mount and it uses that area so i tacked the mount on that corner and used new bolts in it . But low and behold shackle is still crooked. I also built a set of new shackles for it out of 1/2'' plate so i know the shackle is true . Im a skilled welder and i do know for sure than my shackles are true . The other thing is my AMC20 is out of a 77 cj and my cj is a 81 so does anyone know if there is a width difference between a CJ7 and CJ5 maybe they used a CJ7 rear and thats whats up . Any ideas will help i know our 77 CJ5 has got the same problem with the driver side shackle and we have had it since it was new in 77 so we know it has not been thrashed on or changed up .Oh and both are factory v8 jeeps . Ill post some mudding pics of my jeep here soon
