Shackle removal
Hi,
I'm hoping to replace the shackle bushing on my 7 this weekend. I tried to remove the bolt as a test but had a problem.
The nut comes off just fine, but the bolt wont come out even with significant encouragement. The head looks like it might be tapered and pressed into the left side of the shackle assembly.
Should I be able to remove the bolt or does it stay with that side of the shackle when it is disassembled? I attached a picture if that helps.
Thanks!
Thanks!
