Shackles bending
weithman5
I finally put engine on snd added a little extra weight to simulate Transmission body etc. I torqued the new shackle bolts to spec per mfg. note the very slight bend in the shackles due to the length of the center pin. I don’t think this will be a problem but unsure. The line you may see on them is from the mfg it is not a crack
