Should this be here?
1930u
midwest
1975, base cj5, 232 ci, 3-speed, 3:73 differentials
Its a very rough old machine and is scary to drive but it gets better each time I work on it.
I assume what I'm looking at is the stock (under axle mount) spring snubber. My CJ5 has stock springs mounted over the axle...should these even be on the Jeep now?
Thanks.
I've never seen one before, But it looks to be original equipment. Some sort of overload device. I would think it would be hard on the springs when in use. I would take it off unless you are going to haul heavy loads.
Kind of looks like if you remove it the spring will go negative. I would say you have much more interesting problems than the bump stop.:cool:
It does look like an interesting way to re-arch a spring
I think that was used on the early V-6 models to keep the driveline from hitting the starter.
If you had filled out your profile it would have told us what year and drive train you have. That would make it a lot easier to give you an intelligent answer.:cool:
It is a win -win thing. You get a good answer and we look intelligent.:D
I can't see a down side.
Thanks guys. I never gave any thought to the profile. I will look it over.
