Skid plate bolt problem
bluesman423
- NE OKlahoma
- 1977 CJ5 258, Dana 300 with 4:1, SM420, 3.54 Dana 30 and AMC 20
1981 CJ7, 151, SR4, Dana 300, Dana 30 and AMC 20
I installed a 4 inch spring lift this weekend then the problem hit.
There are only 3 bolts holding the skid plate/ cross member to the frame. One missing on one side and three missing on the other. There are no nuts or threads to install new bolts, just an open hole.
What is the best solution to this problem? My CJ7 will see mild to medium trail usage and rock crawling, mostly at Disney, OK and Clayton, OK, and I believe I need all the bolts.
Can I drill through the top section of the frame and use a bolt all the way through?
Thanks if you can help.
