SOA Lift Questions
Out of my mind CJ5
I have been looking at doing a spring over axle lift on my jeep and have heard that i need new spring perches and shock mounts. Why is this? What is wrong with what is on it now?
this is true but if you really have your heart set on soa and got some cash i found a really nice bolt on setup atForgot about the high steer.
Spring under is easier and probably cheaper in the long run because a GOOD lift kit is all inclusive. The lift kit company did all the homework for you already and should be able to provide everything you need for a truly bolt on solution.
makes sense to me. didn't think about thatBecause when you do a spring over axle lift you're moving the spring plate to the TOP of the spring pack. This moves the lower mount up about 5 inches which shortens the shock.
What you can do though is make a new shock mount that welds to the axle. All you need is some box tubing and cut one side of the box off (making a C).
alright so in your alls opinion which is easier/ cheaper/ better. a SOA or just a regular lift kit
the z link setup rocky road sells is an option but they also sell the high steer setup.
