Speedometer gear 1972 CJ5
I thought there was a pin to prevent that gear from sliding. Is sounds like is slides so much it stops engaging the driven gear. Not sure lock tite is the way to go. Should be a mechanical way to lock it in place.The plastic gear on the output shaft looks good as well, this gear will move side to side on the shaft by 2", there is a hatched area in the middle that I'm assuming it should fit tight on and not move. Should I use some type of lock tight? Or? Please advise. Thanks
Please try to keep all the information in one thread so we are all on the same page.So I took the output shaft out, cleaned it up, etched the inside of the plastic gear and used an epoxy, lightly coated the hatched area and inside the plastic gear. Put it all back together after a long cure time and it works perfect. If the gear oil doesn't affect the epoxy it's a done deal.
