Spindle Bearing Removal (Inside Spindle)..
Greggsr219
Spindle bearing removal on a 77 CJ7 , with drum brakes....I had some vibration in the front end, so started rebuilding it...I've taken this jeep one section at at time..bearings are relatively cheap..and since I had it down I decided to change them all out including the ball joints.The bearing inside the spindle according to (Haynes Manual)..calls for it to be pressed out...surely someone has found a way to get the bearing out without a hydraulic press. Need some successful ideas....
