Sprayed out water on ground at tailpipe every morning
CJB4POWERBILL
- Shelby,NC
- 1983 CJ7 258 4.2 I6 - T5/300 - Dana 30 Front - AMC 20 Rear - motorcraft 2100 carb, nuttered factory dist, all smog emisions removed, Bridgestone Desert Dualer 31-10.50-15 tires, Upgraded Heater Blower to the Blazer 103, Sunpro RPM gauge, Sunpro mechanical oil gauge, new main bearings, main rod bearings, oil pump, RMS, distributor gasket, oil pan gasket,
Who wants to answer this one ? When start cold after sitting all night, why does it spit large puddle of water out tailpipe...after initial spray its done spraying...but next morning it does it again. So wheres the water coming from and hows it keep getting in there each time. Condensation ? cracked water jacket leaking into exhaust side ? Yall preach
