Spring Hanger Bolts & Torque Spec
dunebuggy18
San Leandro, CA
1973 CJ5 "Project" Jeep - Frame Swap in Progress! 304 V8, Dana 30 front & Dana 44 rear (3.73 gears), T15 3 spd. & Dana 20 Transfer case, 4" lift and 33's. /
2008 JK - 3" lift, 35's, Sleeved Dana 30 front axle and Dana 44 rear with 4.88 Gears, HD tie rods & trackbar, and...
Ok, I'm finally getting back to working on the CJ again. I have new spring hangers to replace the bent ones currently on the frame, and have not been able to find any info on bolts to replace the rivets that I cut out to remove the hangers. I would think grade 8, and I'll probably use a jam nut to be sure it won't back off, but what about torque spec's? 100 ft/lbs?
Any suggestions??? :confused:
No. Way too much. I don't have the info in front of me but do a search for "prevailing torque for grade 8 bolts". I think it's probably around 40 for 3/8", if that's what they are.
What rivets? Are you relocating your hanger forward to use wrangler springs?
Edit: Here's a chart from Fastenal. Ignore the locknut part. It was a pdf and would only let me copy the whole page.
viewer
3/8-16 dry 45 ftlbs clamp load 6980 lbs
3/8-24 dry 50 ftlbs clamp load 7900 lbs
Weld the 2 sides parallel to the frame rails. I would not weld perpendicular on the frame rail. Why add a stress riser there? Welding causes stress risers. :D
Thanks Guys! :notworthy: And yes, 2 welds along the frame rail per hanger, not across the rail - Stress cracks from the PO's multiple attempts at frame repairs is what started this frame swap! :eek:
What kind of spring hangers did you get? Quality ones shouldn't need welded on. Stock hangers tend to either unroll, crack, or twist.
I went with the M.O.R.E. hangers in the front, but kept the stock version for the rest.
Mountain Off Road Enterprises Part 7686FSH2.0CJ - Front Spring Shackle Hangers
The front stock hangers were bent on mine, but the rest (except one main eye hanger that was slightly bent) all faired pretty well, so I decided to stay with them.
