Spring hanger help?
Spring hanger help?
crust
P-Pines, CA
'76/'79 CJ5, '00 cherokee, '94 YJ, '98 altima
I need help locating mid '90s spring hangers. I'm redoing the new frame I got and the PO welded new hangers to the rear but had none on the front yet. I have searched all the normal sites for the hangers and only found the version used on the '70s.
And these are the style, but look closely.:confused:
the rear of the frame is on the left
Umm are those hangers on backwards?
(If so just use a grinder with a thin cutting disc to cut the welds off and reweld them on correctly) :chug:
Yes, they are backwards. I noticed that when I finally stood back after cleaning and coating the frame.:rolleyes: Not sure if I will be able to save 'em. they have fat welds on the inside also. Thanks for the link, but those are the shackle end, I am looking to replace the backwards hangers. I guess they are called mounts on most of the sites I have looked on. I am going to torch those off and replace all four. I like that type of mount that the PO used.
Try 4wd.com they have them.
Looks like I am getting them from Morris4x4. I'm gonna go to the stock 70s version. they also have unpainted windshield hinges and seals at good prices.
