spring over and axles
jamie
- westminster mass
- 76 cj 5 360, 999 tranny and dana 300 transfer case, dana 44 rear and dana 30 front diff
im thinking about taking out the 4 in lift springs in my CJ5 , and doing a spring over with a pair of stock 1995 wrangler springs. at this time i would most likely do a shackle reversal as well. i have an axle from a 73 blazer, Dana 44 i think, that i was going to use in the front. how much wider is the blazer axle than the stock widetrack axle? i would measure it, but its at my friends house. and my next question is, if i do run this axle, would a 14 bolt rear be the same width? and how do i change the lug pattern on said axles to the stock jeep pattern?
