Spring Pack Center Pin
tvince
KC MO
1978 CJ7
So is there any special propertys to a spring pack center spring other than the round alighnment head.
I am installing my new 3" Black Diamond Springs replacing the RC and need to install some caster shims and the BD uses a 5/16 center pin.
It seems to me that a good 5/16 allen head would do the trick just fine.Or a grade 8 hex head ground round.
But just wanted to check collective knowledge.
Tvince
have you ever seen a car going down the road at an angle?? It more than likely has a sheared spring pin and one of the axles is not square with the other. This may seem like a bad thing but the pin can be replaced, the spring perch, not so much. I would think of it as a shear pin, not to be harder than the spring perch. I would go with a grade 5 my self and that would be why.:cool:
Tvince
Thanks IO thats the kind of knowledge I was lookin for, I can see finish-in this mutch anticapated swap before the weekends out, And still have plenty of time to appreciate all the Mothers in my life!
I use G-8 bolts and grind the heads round. If your U-bolts are properly torqued and re checked they should never get loose enough to be moving around on your perches.
So do these "pins" serve any function other than alignment to the mounting holes in the perches and u-bolt plates?
They do a pretty good job of holding the springs together until the U-bolts are tight.:laugh:
I guess it's mostly when some citizen broadsides you or you loose control in the rain and hit the curb pretty hard that the bolts get sheared, I don't see any way you could break one just driving or even heavy wheeling. I think it is just a good idea to have an expendable part in every system kind of like a fuse or, like I said, a shear pin.
Think about it this way, I would rather break a U-joint than a drive shaft, a drive shaft than an axle shaft, an axle shaft than a ring gear. This is just me but when you replace grade 5 bolts with hardened bolts just give a thought to what is going to break if it doesn't.:D:chug:
x2
using grade 8 hardware where ever it is not needed can be a bad thing, I have seen guys who tried it cause it was hard and ruined stuff. I would use grade 5 here.
