Spring Shackle and Front Axle Move Sideways!
dunebuggy18
- San Leandro, CA
- 1973 CJ5 "Project" Jeep - Frame Swap in Progress! 304 V8, Dana 30 front & Dana 44 rear (3.73 gears), T15 3 spd. & Dana 20 Transfer case, 4" lift and 33's. /
2008 JK - 3" lift, 35's, Sleeved Dana 30 front axle and Dana 44 rear with 4.88 Gears, HD tie rods & trackbar, and...
Ok, so I bought my CJ5 knowing that she needed some help, and I wasn't disappointed! After correcting some serious wiring issues, converting it back from a one-wire alternator to a 3 wire Delco, and replacing a few other electrical components , I fired it up last night and all the electrical basics work great now! Next, I knew that the ball joints needed replacing, and the drag link angle is all wrong, so I that was the project for the day. I thought to my self, I wonder what other surprises are in store? (thinking, axle u-joints, wheel bearings, etc.) - So before I started, I had the wife turn the wheels while I watched the front end components....
I did not expect to see the front springs (and as a result, the axle) move back and forth about 1-2 inches! The shackle mount is flexing, and looks like there is too much play for the spring??? Wrong shackle? Wrong springs?? Both????
I measured the lift: it's a 4" lift (without a drop pitman )
I know that I am going to have to fix the scary weld job on the front shackle mounts, and I am assuming that the front shackles are part of my problem, any other suggestions???
