Starter bolt size??
Vikingone
In my on going battle to solve the grinding on startup which wiped out my flywheel I stumbled across something interesting today. I too the starter apart and ran the gear across the flywheel gear. They do indeed mesh properly. BUT. I put the nose of the starter on the bellhousing and found that the two 3/8x16 bolts had a lot of slop in the bellhousing. I looked at the bellhousing and it appears that one hole was tapped. So I took a tap and retreaded the one to 7/16x14. Ok. So one is good. But the other hole in the bellhousing also holds a 7/16x14 bolt but the starter only accommodates a 3/8x16. Can anyone tell me what size bolts are supposed to bolt down the starter? And do you think I should just drill and tap the starter to accommodate the other 7/16x14 bolt?
