starter issue
BravoBuzzard
- Oklahoma City, Oklahoma
- '84 CJ7. All stock, but looking to upgrade soon.
Recently I had to replace my starter on my '84 CJ7 . After I installed it and hooked everything back up, I tried to start it, and it sounded like grinding metal. I did some research on this, and discovered that when this occurrs, all you need to do is Shim the starter. Well, this starter is 'un-shimable' due to the design.
I took the starter back to the place I bought it from thinking that maybe it was just a bad starter, and since it has a lifetime, or longterm guarantee, I figured it might be a bad starter.
I installed the new starter, hooked everything back up, and ran into a similar problem with grinding metal.
I don't know if I have another starter issue, or what it is. I'm hoping somebody else has ran into this problem and has a suggestion. I had somebody suggest that I need to replace the bell housing because the hole the lower starter bolt goes in may have been wallered out. I looked at it and really couldn't see, but I can't imagine that even if it had a little, that it would cause that much of a difference??
