Starting problems
Vehicle year is 1985, it has the Inline 6 with all Motorcraft ignition components.
I adjusted the timing a few weeks ago, ride was running smooth. Randomly died on me in the heavy rains that we had a few weeks ago (engine, electrical all died), but I was able to get it going again. Got it home, no problems. Got to work the next day without a hitch and it refused to start when I was leaving. After a couple of hours it started back up. I attributed it old spark plugs, which I changed out and it seemed to run great.
Kicked the bucket again the next day. I thought maybe my timing was screwed up, so I reset back to TDC via a way I found on the internet (remove #1 plug, rotate engine till pulley mark meets on the proper line, then rotate oil pump notch fully clockwise, facing the engine it's in the 11oclock position, check to see if rotor matches #1 plug on cap for TDC).
Changed to the mechanical carter and it was running really nice, drove it around (good mileage). I reset to TDC to ensure the best performance, then adjusted it a tad. It ran great. Next morning I decided to go to the gym. I had the same problem when I tried to leave, so I checked the wiring, it seemed that a wire on the coil was bad so I ripped it out and fixed it, car drove but it chugged all the way home. When I got home the car died again.
I checked the timing, appeared fine. I'm still getting spark, replaced the distributor with a working one, ICM works, coil is good. Checked out all the electrical with a test light (clamp on negative, turn car to run, please test light on yellow wire [removed from coil], check for light, then crank, check for light, repeat on + side of battery on green coil wire [removed from coil). Found my starter solenoid was dead so I replaced that to boot.
It just doesn't want to start. Turns over like a champ, got fuel, got spark...just no ignition.
Any ideas where to look? I really don't want to peel the front off to see if the timing has jumped. Too cold and I've never done it before, but if I have to I will. I'm pretty frustrated at the moment, especially with 3 buyers wanting it.
edit : Going to swap out the spark plugs tomorrow, as well as attach the lines directly to the coil instead of with the cap.
