steering box fix
steering box fix
rideforever13
Sarasota, FL
1984 cj-7
6cyl
ive read a couple forums saying that the problem for wondering could be my lift shackles. so im taking them off and am going to do a spring over to help. BUT how do i correcting my steering box so that my steering wheel returns to center coming out of turns?
also anyone know of a dual stabilizer that will work with a spring over?
thanks!
So your going to take off a shackle lift and replace it with a SOA conversion? Just how long are your shackles?!? The SOA should net you about 6"+ of lift, And takes a lot of work/time/$$ to do correctly.
The return to center has to do with your caster (or is it camber?) and must be engineered into the lift, or corrected with shims (to a degree (pun intended :))
IMO, a dual stabilizer is not a solution for a problem, it just covers up the problem for a while. IF your suspension and steering is correctly engineered and build, you will not need the stabilizer.
Please read up all you can on suspension design, how a steering system works, and alignment specs so you can do the job once (more) and do it right.
I'm assuming by your location that you are planning to make a mud buggy? Give us an idea of your plans for it. Tire size is a biggy in terms of lift and usage.
post up some pics of your ride as is, so we can see what your working with, and give some good advice in getting your ride working great! Lots of smart guys here to help ya!
