Steering box identification help
Montanaphilly
Apple valley
None
So this box is on a 75 postal , it's a manual box. I'm looking for a dropped pitman arm , I need help identifying it to order a dropped arm , here are some photos below
Sent from my SM-G955U using Tapatalk
I don't know much about the DJ postal Jeeps, but I thought that they were only 2WD. Just curious why you are putting a dropped pitman arm on a 2WD. That said, I know that gear boxes are readily available. I am pretty sure that the pitman arm from a CJ5 is the same one used on a DJ5, so you should be able to order one for a CJ. Just count the splines and diameter to make sure.
I'm doing a 4x4 conversion , I have a Dana 30 on the front , and I'm getting alot of bump steer on and offroad , the steering box is on the opposite side compared to the cj,
If it is the saginaw (GM) box that most all jeeps have, A pitman arm from a Grand Cherokee will fit. It's a dropped arm.
It looks like same saginaw manual steering box that came on CJs. I would pull the pitman arm, measure the shaft and count the splines.
A pitman arm from a power steering grand cherokee may not work...Generally, Saginaw manual boxes use different pitman arm (different diameter shaft) than the Saginaw power boxes.
There is 32 splines with 4 flat spots evenly spaced,
Also thank you for taking the time to help me , I ordered a dropped pitman for a cj with manual steering , hoping it will fit , don't want to deal with returns
