Steering box issue
csuengr
- Loveland, CO
- 1980 CJ-7 LT1 TF727 NP231-D300 Waggy D44's ARB's 35" tires
I am assuming it is my steering box. The issue is I lost my return to center in the steering. My steering got stiff, as if the power steering was dying, or low on fluid, which it isn't. No noises from the pump. This happened driving down the interstate. I left the Springs and it was fine. When I got off the interstate, it was all funny. No binding in the steering shaft or draglink and tie rod. Steering box is not loose to the frame. Doesn't even budge. I replaced the sector shaft bearing about two months ago. I didn't play with the nut on the top of the box. Just left it alone. It is harder to turn to the left than to the right.
