Steering box needs replacement, what donor vehicle will work?
suburban99
- 1980 CJ7 304 V8
2011 Silverado 4x4
2004.5 Dodge Cummins Diesel
1997 Porsche Boxster
Seems like yards wanted $85 minimum for a used one. And you never really know how "used" they are.
I went to advance auto parts and spent $129 on a reman PS gearbox about 3 months ago. BEST decision I made!
I got one for a 1976 J20 truck... Part number SG16529
There are a couple advantages to using this box over the stock CJ box...
Plus, it was a super simple swap.
I think your right about the reman box versus used. I will try to pick one up next week when I am in Tacoma WA...
Oreilly auto has the CJ7 cardone rebuild part #27-6534=$142.99
But the J20 1976 is part# 27-6524=$116.99
What are the benefits to running the J20, are the hoses the same?
Anyone know the o-ring size for the power steering hose fittings?
Dont you have flare fitting style hoses? I didnt think they started using the o-ring style till later than 1980.... But I could be wrong...
Nope, they are o ring type 18mm fittings. I am pretty sure it is original to the Jeep.
I ordered a reman box from NAPA in Sumas WA..$133.00 + core charge of $160.00 but I can take the old one down with me. No Advance Auto in Washington State...over $280.00 up here in BC...
So which reman box did you order?
If you ordered the older version ( i.e. 1976 ) then it will have the flare fittings. I didnt know you had the newer version with the "o ring" style. You can actually use the older box if you ordered it, and just use an adapter fitting to convert.
I ordered the stock CJ7 replacement for a 1980. I figured if the first one lasted 32 years the next one will outlast me.
