Steering Col. Choice
1moreshot
- Media
- 3
- Seguin, Tx
- 1976 CJ-5 AMC 304 5.0 L 3 speed Dana 30 Front Axle. AMC-20 Rear Axle
Great, thanks. That gives me quite a fews years to choose from. Does the 96 have the tilt?
It does.
and dimmer and wipers on the column.
Can you weld? Or know someone that can?
I did a splice in the steering shaft to mate the 96 to the 77. It was pretty easy stuff.
this may be of interest.
Jeep CJ Steering Column Swap
IO, Can you help me with a axle question? I'm installing a Dana 30 with disc brakes(77). Will I have any problems with the proportion valve being mine is a 76 with drums. Gear ratio is the same.
IO, when you installed that 96 steering col. did you wire up the wipers/mist using the control on the col.? Did you have to use a intermittant wiper control box. I just want to make sure I get everthing I need.
Any other recommendations for compatible steering columns? Mine is a 78 CJ5 . I've heard a rumor that the steering column from old Blazers will work, but I find that hard to believe. I'm planning to go to a junkyard this weekend to look for a replacement column.
Or, is there anyone out there who could rebuild the one I have? Anything I can do to avoid forking out $700 for a new one will be great.
