Steering column 1978 cj5
Cj5darrin
I am having a hard time mounting my steering column after replacing old steel body with fiberglass body. When I put the column over the shaft, the end of the shaft does not stick out enough to mount the steering wheel. The column mounts do not match up with the pedal assembly holes. Does the column collapse?
Any help would be appreciated
