Steering Column falls apart!
CJason7
I just bought my CJ7 . When I got it it had a problem where you could pull the steering wheel and the shaft would move axially in the column. You could pull it up so far that the lock plate no longer caught on the lock pin. I took the column out this weekend and now the shaft came all the way out of the column. Turns out the only thing holding the wheel in was the intermediate shaft u-joint.
I can't figure out what is supposed to hold the shaft and column together. Does anyone have a rebuild write-up?
thanks in advance
thanks in advance
