Steering column play
ftwflh
- Crossville,IL
- 1976 CJ 5, 232 6cyl 3spd lots of rust,good frame,Dana 44s w/373 gears,ProComp 4in lift kit
First off this is my first post.Expect many more!
I have a 96 CJ5 with the steering column play at the bottom where the cap is clipped on.I put a hose clamp around it real tight and it took most of the play out.What I need to know is there a kit to fix this or do I need to find another column?It has a little play in the steering shaft but not much.The box has a little but not bad either.
I want to fix this one step at a time and as reasonably as I can.
