Steering Column swap
MNCJ100
Minnesota
1977 CJ5 - 350 conversion, 1994 Wrangler 4.0 Stock, 1960 Ford F100 292 modified
My 77 CJ5 steering column needs to be replaced. Does anyone know if the 90's Cherokee columns would fit and or what year Wagoneer columns would fit.
I have seen the Cherokee column put in Jeeps and a '90s Cherokee column is pretty much a plug and play.
The bottom of the column will be in issue if its the "D" shaped end instead of the splined end as used in CJs. A steering shaft divorce and marriage may have to happen. I did a CJ/YJ combo for a buddy once.
