Steering Column Upper Bearing install
AZ chip
Mesa, AZ
1978 CJ7 AMC 360 Edelbrock carb, Dana 30 front, Dana 20 transfer, AMC 20 rear, Moser one piece rear axle, Detroit lockers
I have a 1978 Jeep CJ7 . It has a tilt steering wheel. I am trying to get the new bearing and race in to the upper bearing position. Not easy. Anyone done this? Any ideas? Thanks,
I figured it out. I put the bearing and race in the freezer overnight. Then I warmed up the column a little with a copper pipe brazing torch. Just a little. Probably only AMC 150 degrees. Then I LIGHTLY tapped the bearing in. The bearings have lightweight retainers and will not stand a full force blow. I know that from experience. I tapped with a punch on the outside retainer of the bearing. That is a heavier metal. Went in like butter.
