Steering Steering column
I have an 85 CJ7 with all original equipment. My problem is the tilt steering column. I have replaced the actuator switch and rod, ignition switch, but the jeep won’t start unless the steering wheel is tilted all the way down. Once started the steering wheel can be raised and the jeep can be driven without any problems. Any thoughts on the solution is?
