Steering Gear Leaking
Mick
Yucca, AZ
74 CJ5, 304, T15, Dana 20, 3.73
I have a 74 CJ5 with power steering. I noticed a leak from the seal at the input from the steering rod to the gear.
How hard is it to rebuild a steering gear? I was thinking of buying the Master rebuild kit and rebuilding the unit. Then I thought, why go through all of the hassle of a rebuild, just buy another steering gear and be done with it.
Anyone have any experience on rebuilding the steering gear?
As always, thanks for the help/advice!
I haven't rebuilt one, but I've pondered doing so. Here are some links:
https://www.google.com/search?num=1...g+column"+rebuild&aq=f&aqi=&aql=&oq=&gs_rfai=
Rebuilding Steering Column - Mopar Muscle Magazine
Since a Saginaw steering box is a widely-used item, you could grab a junk yard box, rebuild it, and not suffer Jeep withdrawal during prolonged down time. Just be sure it has the same mounting bolt pattern.
You can see from the attached, I didn't follow my own advice.
