Steering Parts ?
Steering Parts ?
ga82832
Indiana
Restored 1980 CJ7,383 STROKED SBC, 400 TURBO TRANSMISSION, Ford 9" rear end, 4 wheel disk brakes
Gents, I want to replace my pitman arm and tie rods, but because I have a Dana 44 front end, stock parts will not fit. I need a straight pitman arm, the tie rod that connects to the pitman arm and the tie rod that runs between the two spindles. Where can I find this stuff or what will fit this. I thought I heard someone say a 77 ford truck has a pitman arm that would fit. Any idea's or suggestions would be great.
If you don't have a cj box, than you are going to have to find out what it's from to find a pitman arm.
The tie rod ends are bigger than a cj if it's a Dana 44 , you will need to buy ends for what ever your 44 came out of.
You might need a custom drag-link to conect them together.
You might want to check this site out for ideas and custom parts.http://www.partsmike.com/tech-help/high-steer/
