Stock Roll Bar metal?
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
I'm actually going against some of my earlier statements. I'm going to modify the existing roll bar on my '75 CJ5 . It will be very roll cage like, but not actually intended as true roll cage duty.
First off I'm going to cut off .... yes I said cutoff ... the angles down tubes going to the rear on the exist. bar. They will be replaced with a more or less 90* bar configured the very similar to the Wrangler's roll bar of today. Some may and will ask why? The stock bar is one of the type with a straight or 90* main roll bar with the angled down tubes starting inside the top radius creating a compound angle. I'm sure this is a very strong arrangement, but it makes it almost impossible to hang or attach anything to the roll bar. I will be using 1.5" Sch. 40 gas pipe. The configuration I'm going to use will allow easy and clean attachment points along with a flat top angle where a basket (like is found on pick-up camper shells) can and will be attached creating a two layer storage space accessible from the ground.
The second phase will be a front, behind the wind screen bar, very similar to a roll cage, but terminating or going under the dash to keep from hindering ingress and egress from the already cramped CJ5 doorway. the top of the bar will have 3 or 4 bars running back and welded to the exist. factory roll bar. They will incorporate a "hump" designed to keep the bikini top from smacking the top of the passengers heads. Two at the very outer edge of the passenger seat space and one possibly two in the middle to hang stuff from. I think I'll be using 1.25" or 1" Sch. 40 gas pipe.
The real question is, what kind of steel is the stock factory roll bar made of? Is it something special or plane old cold rolled steel "pipe"?
