suspension too stiff
You can make a good impact through some simple maintenance with stock springs.
Pull the leaf packs apart and clean them up and new paint I bet after 25+ years there will be rust and crud that increases the friction between each leaf then get some teflon pads from a good spring shop and install them while your at it ditch the fold over spring clamps for some u and bolt style clamps
Then also look closely at shackle angle as too steep will make a stiffer ride
RPM Net Tech Articles: Leaf Springs - Powered by: AFCO
After that you can then start to look at spring rates removing overload springs etc but trying the above is cheap and can have a huge impact depending on state of current set up
