swapping out springs
thistle3585
- IN
- 1979 Jeep CJ5 with '72 304 V8, MC2100carb,T150 trans, AMC20 rear diff with locker, Dana 30 front diff, Dana 20 Tr Case, Procomp Springs, Gabriel Ultra shocks.
I am picking up some leaf springs, basically a suspension kit,from a Jeep in a salvage yard on Saturday and have a couple questions to make sure I'm covering all my bases. Do I need to use the shims and/or perches that are on the yard Jeep or my Jeep? I currently have a 1" lift. I assume that when I go to the 2.5" that it will be 2.5" when done and not 3.5". Is that correct. I ask because I wonder if I need to change my drop pitman arm? I am also pulling off the shocks and steering stabilizer from the yard Jeep. I don't know that I'll be using the stabilizer but it matches the rest of the suspension kit, so I figured I'd grab it. Does the lift affect the stabilizer? Is there anything else that I need to take in to consideration when swapping these out? I have never done any spring work, but it seems pretty straight forward. I plan on using the shackles off the yard Jeep. Do I need to pull the shackles off the springs or can I install the shackles directly to my Jeep without separating them from the springs?
