sways and draglink
zackstheking
anybody found any good sway bar setups for older cj5s photos would be awsome
i appreciate the pictures that will help with brackets but looking for a super heavy sway maybe someting of a one ton really want to try to get rid of the body roll to keep it straight in the pit
stock axles
if one tons are used they would be cut down and arms welded to the end like the aftermarket kits
on our race truck we used spring steel cut it to length build cams for the ends and bolt thru the spring steel rod
thinking of doing the same on the jeep but would not be able to cut the ends of the sway bar due to having to ride in the bushings because you would have to run the cams inside the frame instead of outside the frame
on the truck we used 1.75 outside diameter but its 900 horse and launching at 7200 rpm
