T-150 trans mount
T-150 trans mount
ksouthw80
georgia
1978 CJ7.304, t150,D20 w/teralow- twin stick, dana 30/AMC20. 35 sst's on procomp wheels.
When I pulled my Transmission the mount was so bad that it was already separated from the crossmember and there was no torque mount. I now have All of the correct mounts but I would like to see a picture if possible or can someone explain what hardware to use . I do remember (i think) from years ago that the plate and Transmission mount are held in with studs (put in Transmission ) and nuts..? The new poly mount came with bolts/ washers. I assume they hold the cross member to the mount..?? I really only want to do this 1 time. The Transmission assembly is in and torqued to the engine w/ a floor jack as support... any help is appreciated. The hardware that came out was not right. P/O (bless his heart):mad: had wrong sizes, threads and all..
GOOGLE--Jeep cj Transmission mount with torque arm pictures.
  5.0%
