T150 trans stuck on Bell housing
harborman
SW Michigan
1979 CJ5
I can't seem to budge the Transmission off the Bell Housing on my 79 CJ5 . It has been on there for many years. I have the Transfer Case off but not the trans. I removed the 4 bolts holding the trans on. I tried driving a thin scraper between the case on housing but no lock. I tried hitting the case to turn it a little, no luck. I am soaking the joint with PB Blaster and let it sit.
Any ideas?
I can't seem to budge the trans off the Bell Housing on my 79 CJ5. It has been on there for many years. I have the Transfer case off but not the trans. I removed the 4 bolts holding the trans on. I tried driving a thin scraper between the case on housing but no lock. I tried hitting the case to turn it a little, no luck. I am soaking the joint with PB Blaster and let it sit.
Any ideas?
I was able to get it off by using a sharp chisel and hitting it along the bottom of the Transmission and bell housing. It finally came lose with that and plenty of PB Blaster.
$100.00
  50.0%
