I want to swap out my T-5 for a T-176 , but first I need to find a used T-176Transmission so if any one around the central Fl area has one I'd like to chat with ya. Is there any real good step by step video's out there any one would recomend how to rebuild your T-176 ? Thanks
1979 Jeep CJ5 with 304 V8, T18 Transmission, Dana 20 Transfer case with TeraLow 3:1 gears, 4.88 axle gears, Detroit Locker up front and Ox Locker in back with 1 piece axle shafts, 36" SuperSwamper SX Tires, Shackle reversal, MileMarker Hydraulic winch, MSD 6A ignition.
I can't help you much finding a T-176 . I live far from Florida. All I can add is that going from a T-5 to a T-176 is an easy swap. It should bolt right up to your bellhousing and if it is out of a jeep it will also bolt up to your TCase. The only issue I see will be the drive shafts. The rear drive shaft will need to be lengthened and the front will need to be shortened.
