T4 or T5
T4 or T5
weaverkb
Gainesville, Fl
1980 CJ5`
I tried searching but wasn't able to come up with anything definitive on this. I have an 81 CJ5 with a fairly fresh AMC 258 i6 / 4.2l and a weak/suck SR4 . I have another good SR4 that I can put in it but I don't want to go that route. I'm looking to swap in a T-4 or T-5 in it's place. Yes, I know, just put in a T-176 , T-18 , or whatever but I'm looking for ease of install and cheap. I don't wheel hardcore, so I don't need something that strong. With my 3.73 gears and 33s would it even be necessary for the 5th gear or would it be pointless? I have a line on both of these trannys and need to make a decision.
What's wrong with the SR4 that you have. Whore out? Broke? They are a known weak Transmission but I've seen SR4s wheeled for years that have lasted for a long time as long as you don't abuse it. The T-4 /5s are only a little better.
If you think you need to go down the road faster then the T-5 is what you'll want.
The one in it is completely wore out but the other one is in decent shape. I just don't want to go through the trouble of swapping it out just to have the same issue in a short time.
I think a 3.73 is a good ratio for the AMC 258 i6 / 4.2l , and you could go either route with transmissions. There are numerous gear ratio charts on the net to advise you of what tire size will give you about what rpm.
It will be he same "trouble" to do no matter what Transmission you decide on. The parts you need are well documented and relatively easy to find, remember this is a factory set-up too. If you don't want the same trouble down the road get something else. or not you might get lucky ... you won't, but I'm not very good at predicting the future.
Abusing your Transmission isn't necessarily ramming and jamming around. With these smaller transmissions going with bigger tires and the great traction you get on pavement is abuse. You don't need to be drag racing to strain these light duty transmissions.
When I still had 3:31 R&P in mine with 33" tires the 5th was never used.
Now that I run 4:88 R&P, the 5th is used.
Don't think you'll use it much, if at all. BUT, get it anyway.
With that combo you'll wish you had it when you get on the highway. And besides the extra gear, the T-5 is just a T-4 , so it won't hurt to have that extra gear even if you don't need it. But I'd bet you will. I do.
Ahhhh a gamblin' man, I like it!
Thanks guys. I found a T-5 nearby and believe I am going to go get it.
Don't use ATF fluid in a Jeep T-5 .
Get some 75W-90 syn gear oil.
Only the World Class T-5 uses ATF as the correct oil.
Good luck,
